[fdo-dev] shp
Haris Kurtagic
haris at sl-king.com
Wed Nov 1 13:48:48 EST 2006
Hi Robert,
I wasn't reading enough, my mistake.
I see in docs on web FDO 3.0 vs 3.2 that you already added new functions
in schema capabilitie to check for data types precisions. I was behind
with a comment.
Haris
From: Robert Fortin [mailto:robert.fortin at autodesk.com]
Sent: Wednesday, November 01, 2006 3:16 PM
To: dev at fdo.osgeo.org
Cc: Haris Kurtagic
Subject: RE: [fdo-dev] shp
In FDO 3.2 there was new capabilities added which provides info on
schema, class, properties limits.
Most of this info can be retrieved from FdoISchemaCapabilities interface
returned by the FdoIConnection::GetSchemaCapabilities() method.
The limit on the property is derived by the dbf limit.
For SHP it will return the following information:
Capability
Value
Class Name Size Limit
255
Data Store Name Size Limit
255
Description Size Limit
0
Property Name Size Limit
11
Schema Name Size Limit
7
Reserved Characters
Dot, Colon
Supports Default
False
Supported Identity Property Types
FdoDataType_Int32
Maximum BLOB/CLOB Length
Unlimited
Maximum String Length
255
Maximum Decimal Scale and Precision
255
255
Maximum Decimal Precision
255
Hope it helps!
RF
Sent: Tuesday, October 31, 2006 6:07 PM
Cc: Haris Kurtagic
This limitation in SHP files is coming from dbf file format limitation.
Romica.
Sent: Tuesday, October 31, 2006 6:04 PM
I have tried to ask something else, in SHP provider there is limitation
of 255 when you want to create a new schema a new property.
I am not asking about already created classes and their properties, but
about detailed information about data types suported by provider.
Haris
From: Greg Boone [mailto:greg.boone at autodesk.com]
Sent: Wednesday, November 01, 2006 12:00 AM
This kind of information is too specific to be supplied in the
capability information supplied by the provider. This information is
datastore/schema dependant. To get this information, you would need to
access the schema returned by the Provider through a DescribeSchema
command. Only the returned schema from the provider connection can
accurately provide this information
See the following class in the FDO API for one interface that supplies
the information you request.
class FdoDataPropertyDefinition : public FdoPropertyDefinition
Greg
Sent: Tuesday, October 31, 2006 5:44 PM
Subject: [fdo-dev] shp
Is a column wide for shp/dbf limited to 255 (as I think is written in
provider) ?
I think we need also beside provider describing data types which it
supports, also interface for describing supported widths,scales, etc..
for those data types (if it is not somewhere already).
Thank you,
Haris
URL: http://lists.osgeo.org/pipermail/fdo_dev/attachments/20061101/88e6e0a8/attachment.html
More information about the Fdo_dev
