[fdo-dev] XMLSchema.xsd not UTF-8?
Pierre Dalcourt pierre.dalcourt at autodesk.com
Mon Nov 6 12:31:36 EST 2006
The problem lies simply in that every person that makes an edit to such
a file risks introducing non-utf8 characters if they are using a non-utf
editor.  In the case of XMLSchema.xsd it was a copyright notice that was
added at some point which inadvertently caused this problem.
Pierre
-----Original Message-----
From: Mateusz Loskot [mailto:mateusz at loskot.net]
Sent: November 6, 2006 12:10 PM
To: dev at fdo.osgeo.org
Subject: Re: [fdo-dev] XMLSchema.xsd not UTF-8?
Brent Robinson wrote:
> Hi Mateusz,
> I checked a couple of FDO xsd files and they are ANSII encoded.
> However,
> it would be easy to change them to UTF8. Offhand, I can't think of any
> side effects from making this change.
Brent,
If these documents are not encoded as correct UTF-8,
why the XML prolog declares this encoding?!?
<?xml version='1.0' encoding='UTF-8'?>
Cheers
Mateusz Loskot
http://mateusz.loskot.net
To unsubscribe, e-mail: dev-unsubscribe at fdo.osgeo.org
For additional commands, e-mail: dev-help at fdo.osgeo.org
More information about the Fdo_dev mailing list
