[fdo-dev] SHP build broken in trunk
Traian Stanev traian.stanev at autodesk.com
Thu Nov 9 11:23:49 EST 2006
Do you mean that things should be checked into trunk and merged into
branch (if needed) instead?
  _____
Sent: Thursday, November 09, 2006 11:20 AM
To: dev at fdo.osgeo.org
Subject: RE: [fdo-dev] SHP build broken in trunk
Done.
BTW, I think this requirement to merge back to the trunk will be a
source of problems :-(
Thanks,
Dan.
  _____
Sent: Thursday, November 09, 2006 10:59 AM
Traian,
I think there was a merge problem from 3.2.x to the trunk.
We will fix that.
RF
  _____
Sent: Thursday, November 09, 2006 10:42 AM
Subject: [fdo-dev] SHP build broken in trunk
The SHP provider does not currently compile from the trunk.
The files ShpCreateSpatialContextCommand.cpp and ShpCompareHandler.cpp
are missing.
Can someone take care of that?
Traian
URL: http://lists.osgeo.org/pipermail/fdo_dev/attachments/20061109/e801c559/attachment.html
More information about the Fdo_dev mailing list
