[fdo-dev] SHP build broken in trunk
Robert Fortin
robert.fortin at autodesk.com
Thu Nov 9 12:05:41 EST 2006
Traian,
You got it right. Trunk is the sandbox. 3.2.x is the branch that we
want to stabilize.
RF
_____
Sent: Thursday, November 09, 2006 11:59 AM
To: dev at fdo.osgeo.org
Subject: RE: [fdo-dev] SHP build broken in trunk
Isn't the branch supposed to be the more stable copy, that's to be
released soon, while trunk is the free for all where all submissions
(new code) go?
_____
Sent: Thursday, November 09, 2006 11:35 AM
I mean the current requirement is only to merge into trunk. No testing.
A build problem is easy to fix as opposed to a run time one.
In short, dropping untested code is not a proffesional thing to do.
Besides, what's the purpose of a branch other than being a sandbox?
BTW, I missed those 2 files because SVN merge didn't work and I merged
the hard way instead...
Dan.
_____
Sent: Thursday, November 09, 2006 11:24 AM
Do you mean that things should be checked into trunk and merged into
branch (if needed) instead?
_____
Sent: Thursday, November 09, 2006 11:20 AM
Done.
BTW, I think this requirement to merge back to the trunk will be a
source of problems :-(
Thanks,
Dan.
_____
Sent: Thursday, November 09, 2006 10:59 AM
Traian,
I think there was a merge problem from 3.2.x to the trunk.
We will fix that.
RF
_____
Sent: Thursday, November 09, 2006 10:42 AM
Subject: [fdo-dev] SHP build broken in trunk
The SHP provider does not currently compile from the trunk.
The files ShpCreateSpatialContextCommand.cpp and ShpCompareHandler.cpp
are missing.
Can someone take care of that?
Traian
URL: http://lists.osgeo.org/pipermail/fdo_dev/attachments/20061109/0d983196/attachment.html
More information about the Fdo_dev
