Hi, I've noticed signatures of some RDBI functions have changed. In rdbi_init.c for MySQL, char* parameters for run_sql, connect and sql changed to const char*. Are you going to change also MySQL signatures of these functions? As I see, mysql_sql, mysql_run_sql and mysql_connect still use non-const params. Cheers -- Mateusz Loskot http://mateusz.loskot.net
