GDAL version in the trunk
Traian Stanev
traian.stanev at autodesk.com
Fri Oct 6 11:00:48 EDT 2006
The version of GDAL in the svn trunk seems to be 1.3.1. Is there any
specific requirement that this version be used by FDO (and the GDAL
provider)?
The reason I'm asking is because the OGR provider uses API that was
added to OGR starting with version 1.3.2. This means whoever want to
compile the OGR provider needs to get their own newer GDAL. It's easy
enough on Linux, but it makes Windows development on the provider quite
a pain (since one has to get all the other dependencies like proj and
geos and compile those too...).
Traian
URL: http://lists.osgeo.org/pipermail/fdo_dev/attachments/20061006/514c068d/attachment.html
More information about the Fdo_dev
