[fdo-dev] GDAL version in the trunk
Traian Stanev
traian.stanev at autodesk.com
Fri Oct 6 12:47:45 EDT 2006
To go one step further... Does it make sense for the build script to get
GDAL from its home server rather than the copy we make in the FDO
trunk?
Traian
-----Original Message-----
Sent: Friday, October 06, 2006 12:46 PM
To: dev at fdo.osgeo.org
Subject: RE: [fdo-dev] GDAL version in the trunk
The WMS provider also uses GDAL. There is no known reason why we cannot
upgrade the trunk to GDAL 1.3.2.
Sent: Friday, October 06, 2006 11:24 AM
Subject: Re: [fdo-dev] GDAL version in the trunk
Traian Stanev wrote:
> Hi,
> The version of GDAL in the svn trunk seems to be 1.3.1. Is there any
> specific requirement that this version be used by FDO (and the GDAL
> provider)?
> The reason I'm asking is because the OGR provider uses API that was
> added to OGR starting with version 1.3.2. This means whoever want to
> compile the OGR provider needs to get their own newer GDAL. It's easy
> enough on Linux, but it makes Windows development on the provider
quite
> a pain (since one has to get all the other dependencies like proj and
> geos and compile those too...).
Traian,
The fdogdal provider would work fine with 1.3.2, and I would like to see
an upgrade. My only concern is if parts of FDO or MapGuide might be
using the OGR coordinate system support and depending on local
modifications to the code.
However, I have done a comparison of all the .cpp files in gdal/ogr
(where most of the coordinate system stuff is) and there are no apparent
differences from the stock 1.3.1. So I think we would be safe to
upgrade to 1.3.2.
Best regards,
I set the clouds in motion - turn up | Frank Warmerdam,
warmerdam at pobox.com
and watch the world go round - Rush | President OSGeo,
http://osgeo.org
To unsubscribe, e-mail: dev-unsubscribe at fdo.osgeo.org For additional
commands, e-mail: dev-help at fdo.osgeo.org
More information about the Fdo_dev
