[fdo-dev] GDAL version in the trunk
Greg Boone greg.boone at autodesk.com
Fri Oct 6 14:33:37 EDT 2006
Yes. I like this idea.
We could do the same and add a --with-gdal option to the WMS provider,
etc...
Greg
-----Original Message-----
From: Mateusz Loskot [mailto:mateusz at loskot.net]
Sent: Friday, October 06, 2006 2:28 PM
To: dev at fdo.osgeo.org
Subject: Re: [fdo-dev] GDAL version in the trunk
Frank Warmerdam wrote:
> I do look forward to improving the FDO build mechanisms so that an
existing
> external version of GDAL can be used, as least optionally, at some
point.
I vote to extend this concept.
I'm going to add --with-boost option to ./configure script so user
will be able to select his own existing of Boost installation.
If no --with-boost option is provided, Thirdparty's Boost will be used.
Do you also like this idea?
Cheers
Mateusz Loskot
http://mateusz.loskot.net
To unsubscribe, e-mail: dev-unsubscribe at fdo.osgeo.org
For additional commands, e-mail: dev-help at fdo.osgeo.org
More information about the Fdo_dev mailing list
