[fdo-dev] GDAL version in the trunk
Traian Stanev traian.stanev at autodesk.com
Fri Oct 6 15:01:47 EDT 2006
On Linux it does. However on my Linux laptop I never had a problem
anyway since libraries get installed in /usr which is automatically
visible, even without having a special --with- option. I simply deleted
thirdparty in order to compile against the available libraries. :-) On
x64, the stuff in thirdparty doesn't really compile anyway, but that's a
whole different discussion.
Traian
-----Original Message-----
From: Mateusz Loskot [mailto:mateusz at loskot.net]
Sent: Friday, October 06, 2006 2:55 PM
To: dev at fdo.osgeo.org
Subject: Re: [fdo-dev] GDAL version in the trunk
Traian Stanev wrote:
> Well, none of that really helps my original problem, since one would
> still need to get and compile a second copy of GDAL. Pointing the
> compiler to the correct directory is the easiest part...
Indirectly, I think it helps.
If all FDO dependencies are supported through --with-<dependency>
option, then it will be possible to not to download Thirdparty module at
all but use existing installation of libraries.
I consider "use existing installation" as equivalent to "get GDAL from
its home server". Though, I might have misunderstood the original
problem.
Cheers
Mateusz Loskot
http://mateusz.loskot.net
To unsubscribe, e-mail: dev-unsubscribe at fdo.osgeo.org For additional
commands, e-mail: dev-help at fdo.osgeo.org
More information about the Fdo_dev mailing list
