[fdo-dev] Re: FW: [fdo-users] RE: [fdo-dev] Query on MySQL FDO
Romica Dascalescu Romica.Dascalescu at autodesk.com
Thu Oct 12 10:40:46 EDT 2006
Hi Rajneesh,
Could you please tell me on which project (.sln and .vcproj) do you have
this error?
Could you please provide me more information?
Thanks,
Romica.
-----Original Message-----
From: Rajneesh Verma [mailto:rajneesh at klgsystel.com]
Sent: Thursday, October 12, 2006 2:34 AM
To: Romica Dascalescu
Cc: dev at fdo.osgeo.org; users at fdo.osgeo.org
Subject: [fdo-dev] Re: FW: [fdo-users] RE: [fdo-dev] Query on MySQL FDO
Hi Romica,
Thanks for the guidance. However, we are still facing problem as given
below:
We have already done checkout of utilities folder and are getting the
error
message as below:
c:\program files\microsoft visual studio 8\vc\atlmfc\include\afx.h(24)
: fatal error C1189: #error :  Building MFC application with /MD[d] (CRT
dll
version) requires MFC shared dll version. Please #define _AFXDLL or do
not
use /MD[d]
Regards
Rajneesh
> From: Romica Dascalescu [mailto:Romica.Dascalescu at autodesk.com]
> Sent: Tuesday, October 10, 2006 11:44 PM
> To: dev at fdo.osgeo.org; users at fdo.osgeo.org
> Cc: Rajneesh Verma
> Subject: [fdo-users] RE: [fdo-dev] Query on MySQL FDO
> Hi,
> Because '[FDO Open Source]\Utilities' directory is not on your local
> disk I think you took from SVN only fdo, thirdparty and rdbms. You
need
> also the utilities for providers.
> You can use checkoutsvn.bat to get/update your working folder by using
> -w command e.g.:
> checkoutsvn.bat -w=fdocore -w=rdbms -u=xxx -p=xxx -o=xxx -s=xxx
> Or
> checkoutsvn.bat -w=fdo -w=utilities -w=rdbms -u=xxx -p=xxx -o=xxx
-s=xxx
> The option fdocore include utilities option.
> Before running checkoutsvn.bat, please update it from SVN.
> After this command you should have and build the utilities without any
> problems.
> If you still have problems please let me know.
> Regards,
> Romica.
Manjeet Sharma
Software Engineer
Daffodil Software Ltd.
To unsubscribe, e-mail: dev-unsubscribe at fdo.osgeo.org
For additional commands, e-mail: dev-help at fdo.osgeo.org
More information about the Fdo_dev mailing list
