[fdo-dev] [fdordbms] UnitTest segmentation fault
Mateusz Loskot
mateusz at loskot.net
Thu Oct 12 12:02:59 EDT 2006
Romica Dascalescu wrote:
> Hi Mateusz,
> I will fix the unit tests by changing UnitTestUtil::GetEnviron() to
> return "" and not NULL.
Romica,
Thanks.
> You will be able to send an empty password by:
> - Using a string like service=mysqlserver;username=root;password=;
> - Not setting the password in init file e.g.
> The default value for password is "".
OK
> There is no rule to fill up these parameters. If you want to be able to
> connect to a server you must set the data which the server needs (at
> least service and username) otherwise the connection will fail.
OK, I do expect it will fail if my parameters are incomplete,
but I expect it will fail gracefully, with some meaningful message,
instead of throwing segmentation fault.
That's what is my first long message all about.
> The parameters from initfiletest take set values or if missing take the
> default values.
> As main rule is better to consider all parameters are required.
OK, I'll stick to it.
Cheers
Mateusz Loskot
http://mateusz.loskot.net
More information about the Fdo_dev
