[fdo-dev] fdo insert command
Orest Halustchak
orest.halustchak at autodesk.com
Tue Oct 17 19:45:52 EDT 2006
Hi Haris,
Yes, the reader returned from the insert command should return the id's
of the inserted records. This is particularly needed if the id's are
auto-generated. The actual mechanism of auto-generating new id's is up
to the provider. Oracle would use sequences, other rdbms would use
autonumber or related concepts.
Map expects to get this reader from every insert. It uses this
information for example to update the data table and cached information
for newly created features.
To avoid having Map try to insert records immediately with null values,
change the Edit menu option for update edits automatically to off (I
don't remember the exact menu item name - I don't have the Map ui in
front of me right now, but I think it's the first item under Edit).
Then, once you finish adding the geometry and setting the properties
that you want, you can check-in the feature or features.
Thanks,
Orest.
-----Original Message-----
Sent: October 17, 2006 6:52 PM
To: dev at fdo.osgeo.org
Subject: [fdo-dev] fdo insert command
I am little confused how FDO Insert Command should work, and
what it should return.
From documentation I understand it should return reader with
feature id's of new records filled, for single and also for batch
insert. Is this true and necessary? Could be problem for some rdbms ?
Also I don't quite understand how Map is using insert command
and null values. It seems to me that it is calling Insert command
immediately after creating new geometry without user filling Null values
All this I am testing on foreign schema's (without fdo metadata)
I hope that I put together understandable questions.
Haris
URL: http://lists.osgeo.org/pipermail/fdo_dev/attachments/20061017/6b570f1c/attachment.html
More information about the Fdo_dev
