bulk copy
Haris Kurtagic haris at sl-king.com
Thu Oct 19 19:20:57 EDT 2006
I can successfully use King.Oracle provider to query and edit data
inside Autodesk MAP.
When I try MAP command for Bulk Copy, I can't use King.Oracle connection
beacuse It doesn't appear in list box (Data Source - Connection Name).
I suppose provider needs to satisfy some capabilities
(FdoCommandType_CreateDataStore, FdoCommandType_ApplySchema,...) ?
If someone can point me into right direction ?
I couldn't find anything in docs.
Thank you,
Haris
URL: http://lists.osgeo.org/pipermail/fdo_dev/attachments/20061020/01e83c2f/attachment.html
More information about the Fdo_dev mailing list
