[fdo-dev] FW: FW: [fdo-users] RE: [fdo-dev] Re: FW: [fdo-users] RE: [fdo-dev] Query on MySQL FDO
Greg Boone greg.boone at autodesk.com
Fri Oct 20 12:57:20 EDT 2006
The MySQL provider contained in the fdo.osgeo.org Subversion is not
compatible with FDO 3.1. The MySQL provider is only compatible with FDO
3.2, which is the version of FDO in the Subversion trunk.
Greg
  _____
From: Rajneesh Verma [mailto:rajneesh at klgsystel.com]
Sent: Friday, October 20, 2006 3:27 AM
To: dev at fdo.osgeo.org
Cc: Partha P. Sarkar; 'Manjeet Sharma'
Subject: FW: [fdo-dev] FW: FW: [fdo-users] RE: [fdo-dev] Re: FW:
Hi Romica,
I need some information from you  that regarding these issues:
Is it possible to Build the open source code for FDO provider for MySQL
with open source FDO 3.1  means , is  open source  MySQL FDO provider
(that i have) is compaitible with open source FD0 3.1. I need this
information , as I am getting errors, when I try to build Fdo provider
for MySQL with FDO 3.1.
If  above mentioned build process is possible, then can i Integrate the
generated .dll files with Autodesk Map 2007 successfully.
Thanks
On 10/18/06, Robert Fortin <robert.fortin at autodesk.com> wrote:
Map 2007 is compatible with FDO 3.1 providers.  You can find tarballs on
https://fdo.osgeo.org/servlets/ProjectDocumentList?folderID=93&expandFol
der=93&folderID=0  for SDF and SHP.  For preview of additional providers
(ArcSDE, MySQL, ODBC, WFS/WMS), you can find them at
https://mapguide.osgeo.org/servlets/ProjectDocumentList?folderID=100&exp
andFolder=100&folderID=0
R050 is basically equivalent to Map 2007 SP2 and MapGuide 1.0 release.
R071 is part of the next service pack for MapGuide.  It is compatible
with Map 2007 SP3.
MapGuide 1.2  will be supporting FDO 3.2 providers.  Map will support
this version of FDO in its next release.
RF
  _____
Sent: Wednesday, October 18, 2006 12:10 AM
To: Romica Dascalescu; dev at fdo.osgeo.org; Partha P. Sarkar
Cc: 'Manjeet Sharma'
Subject: RE: [fdo-dev] FW: FW: [fdo-users] RE: [fdo-dev] Re: FW:
Hi Romica,
May we know the version which is supported by MYSQL provider?
Regards
Rajneesh
  _____
From: Romica Dascalescu [mailto:Romica.Dascalescu at autodesk.com]
Sent: Tuesday, October 17, 2006 8:38 PM
To: dev at fdo.osgeo.org; Rajneesh Verma; Manjeet Sharma
Cc: ganesh.bansal at daffodildb.com ; parveen.agarwal at daffodildb.com
Hi Rajneesh,
For that version of Map which you have, is no open source code for MySQL
provider available.
For that version of Map you have only FDO, SHP and SDF providers
available.
Regards,
Romica.
	-----Original Message-----
	Sent: Tue 10/17/2006 9:34 AM
	To: Romica Dascalescu; 'Manjeet Sharma'; dev at fdo.osgeo.org
	Cc: ganesh.bansal at daffodildb.com; parveen.agarwal at daffodildb.com
	What versions does it support?
	Regards
	Rajneesh
  _____
	Sent: Tuesday, October 17, 2006 6:21 PM
	To: Manjeet Sharma; dev at fdo.osgeo.org
	Cc: Rajneesh Verma; ganesh.bansal at daffodildb.com;
	Hi Manjeet,
	Latest FDO is not supported by the version of Map which you
having.
	Regards,
	Romica.
[mailto:manjeet.sharma at daffodildb.com]
		Sent: Tue 10/17/2006 1:07 AM
		Subject: Re: [fdo-dev] FW: FW: [fdo-users] RE: [fdo-dev]
		Hi Romica,
		I am sending you the following configuration details for
FDO provider :
		Product name: Autodesk Map 3D 2007
		Product version: A.54.0 (UNICODE)
		Product service pack: 0
		License type: Standalone - Locked
		License behavior: Unregistered Version
		License usage type: In Trial
		FDO provider version: 3.2.0.0
		and we could not find the library file
MgFdoMySQLOverrides.dll  after
		build process at the following locations:
		 \\Providers\GenericRdbms\Managed\bin\debug\ and
		\\Providers\GenericRdbms\Managed\bin\release\
		but we have another library file
		OSGeo.FDO.Providers.MySQL.Overrides.dll at the same
path. we tried to
		use the same but the error message during autodesk
startup is same as
		i have told you earlier.
		i have also tried all the newly build fdo core dll file
(including
		debug dependencies (Xalan-C_1_7_0D.dll,
XalanMessages_1_7_0D.dll,
		xerces-c_2_5_0D.dll) by placing all those files.
		Right now i am trying to build the FDO provider  using
FDO 3.0.0.0 version
		Thanks
Manjeet Sharma
Software Engineer
Daffodil Software Ltd.
URL: http://lists.osgeo.org/pipermail/fdo_dev/attachments/20061020/67f913a3/attachment.html
More information about the Fdo_dev mailing list
