[fdo-dev] Enumerating connection properties
Romica Dascalescu
Romica.Dascalescu at autodesk.com
Mon Oct 23 18:32:35 EDT 2006
The example is not up to date.
Regards,
Romica.
-----Original Message-----
From: Mateusz Loskot [mailto:mateusz at loskot.net]
Sent: Monday, October 23, 2006 6:16 PM
To: dev at fdo.osgeo.org
Subject: Re: [fdo-dev] Enumerating connection properties
Romica Dascalescu wrote:
> Hi Mateusz,
> MySQL: DataStore property is enumerable but you will be able to get
the
> values only if you are in pending state with the connection.
> If you are not connected to a server you can not take the schemas!
Romica,
Yes, I understand it. It's a two-step connection procedure.
Although, I think the ExerciseFdoConnection.cpp example from SDK's
DevGuideExample package is incorrect.
There is a function ExerciseFdoConnection::ConnectToProvider()
with following body:
connection = connectionManager->CreateConnection(providerInternalName);
connectionInfo = connection->GetConnectionInfo();
connectionPropertyDictionary =
connectionInfo->GetConnectionProperties();
retval = GetConnectionPropertyValues(connectionPropertyDictionary,
connectDialog);
if (retval == 0) {
connectState = connection->Open();
switch (connectState) {
case FdoConnectionState_Busy: break;
case FdoConnectionState_Closed: break;
case FdoConnectionState_Open : break;
case FdoConnectionState_Pending :
connectDialog);
if (retval == 0) {
break;
As you see, the GetConnectionPropertyValues() function (member of
ExerciseFdoConnection class) is called first time *before* any
call of Open() step.
In the body of GetConnectionPropertyValues() I see:
if (IsEnumerable)
// get the list of valid values
EnumeratedValues = dictionary->EnumeratePropertyValues(propertyName,
numValues);
So, the result is as follows:
1. Call GetConnectionPropertyValues()
1.1. Call dictionary->EnumeratePropertyValues()
2. Call connection->Open()
2.1. Check connection state
2.2. Call connection->Open() again if needed
The step 1.1 is called before any call of Open(), so if there is any
enumerable property detected in the loop, how it's supposed to work?
Or may be this example is not up to date?
Cheers
Mateusz Loskot
http://mateusz.loskot.net
To unsubscribe, e-mail: dev-unsubscribe at fdo.osgeo.org
For additional commands, e-mail: dev-help at fdo.osgeo.org
More information about the Fdo_dev
