[fdo-dev] WMS provider install
Romica Dascalescu Romica.Dascalescu at autodesk.com
Tue Oct 24 13:51:31 EDT 2006
Hi Jason,
These libraries are installed by build_thirdparty.bat script.
This script has also an install parameter.
Romica.
-----Original Message-----
From: Jason Birch [mailto:Jason.Birch at nanaimo.ca]
Sent: Tuesday, October 24, 2006 1:34 PM
To: dev at fdo.osgeo.org
Subject: RE: [fdo-dev] WMS provider install
When I run the build.bat file in windows with the -install option (or
something like that) these DLLs don't get copied to the destination.
Jason
From: Mateusz Loskot [mailto:mateusz at loskot.net]
Sent: Tuesday, October 24, 2006 10:06
Subject: Re: [fdo-dev] WMS provider install
Jason Birch wrote:
> Hi all,
> Should the install option on the build be copying the xalan,
> xalanmessages, and xerces dlls into the installation target for the
> WMS provider?
Jason,
Generally, fdocore uses it's own copies of xalan, xerces, etc. libraries
(from Thirdparty), so according to my understanding the answer is "Yes".
Because fdocore is required by all FDO providers, then all its
dependencies (xerces, xalan, etc.) should be installed too.
When fdocore is built on Linux, then all these libraries are compiled
and copied to /usr/local/fdo-X.Y.Z
Cheers
Mateusz Loskot
http://mateusz.loskot.net
To unsubscribe, e-mail: dev-unsubscribe at fdo.osgeo.org For additional
commands, e-mail: dev-help at fdo.osgeo.org
For additional commands, e-mail: dev-help at fdo.osgeo.org
More information about the Fdo_dev mailing list
