[fdo-dev] FGF polygon
Haris Kurtagic
haris at sl-king.com
Wed Oct 25 10:04:52 EDT 2006
Thanks for answear.
I hoped it would be a rule.
I asked this question beacuse in fdo provider I am getting polygon whith
outer ring which is not counter-clockwise
This request comes from MG when it queries for selection of feature.
I didn't quite unterstood why enforcing such rule would cause
incompatibility.
Haris
From: Gavin Cramer [mailto:gavin.cramer at autodesk.com]
Sent: Wednesday, October 25, 2006 3:58 PM
To: dev at fdo.osgeo.org
Subject: RE: [fdo-dev] FGF polygon
Hello, Haris.
Nominally, we would refer to the OGC abstract specifications, which has
outer rings as counter-clockwise and inner rings as clockwise for the
upward-facing surface. Most data sources (that care) use this rule.
However, handling of FGF generally does not enforce such a rule, in
order to avoid incompatibility with any data sources that may vary. Any
enforcement would have to take place in the FDO Provider for a specific
data source.
Gavin
Sent: Wednesday, October 25, 2006 7:24 AM
Subject: [fdo-dev] FGF polygon
Is order of points defined in FGF polygon?
Does outer line string is always in counter/clockwise and inner in ...
Is there any rule on which we can count on?
Thanks,
Haris
URL: http://lists.osgeo.org/pipermail/fdo_dev/attachments/20061025/2052e89c/attachment.html
More information about the Fdo_dev
