[fdo-dev] GetProviderDatastoreType()
Frank Warmerdam
warmerdam at pobox.com
Thu Oct 26 22:27:11 EDT 2006
Traian Stanev wrote:
> Same question applies to the OGR provider.
> In theory one could wait until the connection is open and figure out
> what the underlying data source is, but I didn't do that (so far). I
> just made it return Unknown.
> The downside (and I'm relating something that was explained to me when I
> asked the same question) is that a MapGuide feature source is not
> portable when you return Unknown -- meaning that if the connection is to
> a file, the client logic would know to copy the file also when moving a
> feature source around. With Unknown, it can't know that so copying a
> feature source would require manual work by the user.
Traian,
I'm guessing that copying a file based connection would also require
correct implementation of the ConnectionInfo::GetDependentFileNames(),
is that right?
Since I am in no position to do that accurately currently for GDAL, I
guess I might just as well return _Unknown.
Thanks for answer!
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
More information about the Fdo_dev
