[fdo-dev] SHP provider
Haris Kurtagic
haris at sl-king.com
Sun Oct 29 11:56:19 EST 2006
As a meter a fact it is very simple, basically for shp provider data
store is the folder.
Apply schema will create shp files in folder (data store).
Anyhow I agree that this command should be implemented, it is important
to try to keep consistency across providers, to have a common level of
functionality as high as possible.
Haris
-----Original Message-----
From: Mateusz Loskot [mailto:mateusz at loskot.net]
Sent: Sunday, October 29, 2006 2:46 PM
To: dev at fdo.osgeo.org
Subject: Re: [fdo-dev] SHP provider
Haris Kurtagic wrote:
> Hi,
> Shape provider is suporting very limited range of fdo data type's.
> I believe it is small change to add double,single int32,int64,..
> Fdo shp provider is open for contributations ?
Haris, I'd like to join your question.
I'm also wondering the reason CreateDataStore command has not been
implemented yet.
Theoretically, it seems as not a big challenge, but I suppose there are
some details which I can't see but which make it tricky.
I'd be thankful for some comments from SHP provider developer(s).
Cheers
Mateusz Loskot
http://mateusz.loskot.net
To unsubscribe, e-mail: dev-unsubscribe at fdo.osgeo.org For additional
commands, e-mail: dev-help at fdo.osgeo.org
More information about the Fdo_dev
