[fdo-dev] Sl-king Oracle Provider
Haris Kurtagic haris at sl-king.com
Mon Oct 30 16:59:45 EST 2006
Hi
- I think I covered all geomerty types, or at least I've tried to. If
you can give me some sample data I can test it also.
- I am not sure, isn't that dialog standard MAP dialog ? I have tested
it in MAP (not that extensively that is true).
  But I will soon release version which will also allow editing in MAP.
Haris
From: Robert Fortin [mailto:robert.fortin at autodesk.com]
Sent: Monday, October 30, 2006 10:51 PM
To: dev at fdo.osgeo.org
Subject: [fdo-dev] Sl-king Oracle Provider
Haris,
I tried sl-king Oracle provider 0.3.3 with Map 2007 I noticed 2
problems:
- Not all the feature were loaded from a given layer.  Is there
currently some restriction around what geometry it can handle? it could
explain why I was not able to retrieve all the data.
- There was dialog that seems to be waiting for something inside Map
"Loading Feature schema caching..."  Was sl-king provider tried with Map
or just with MG?
RF
URL: http://lists.osgeo.org/pipermail/fdo_dev/attachments/20061030/1ec6f41f/attachment.html
More information about the Fdo_dev mailing list
