[fdo-dev] single-char to wide-char conversion
Greg Boone
greg.boone at autodesk.com
Tue Sep 5 10:19:17 EDT 2006
If you are converting to/from multibyte, use the following marcos....
...\Utilities\Common\Inc\FdoCommonStringUtil.h
multibyte_to_wide
wide_to_multibyte
If you are converting to/from utf8, use the functions...
...\Fdo\Unmanaged\Inc\Common\StringP.h
FdoStringP::Utf8FromUnicode
FdoStringP::Utf8ToUnicode
We have the multibyte macros because class FdoStringP does not act on
multibyte strings.
Greg
-----Original Message-----
From: Mateusz Loskot [mailto:mateusz at loskot.net]
Sent: Monday, September 04, 2006 11:06 PM
To: dev at fdo.osgeo.org
Subject: [fdo-dev] single-char to wide-char conversion
What's the recommended procedure to convert single-byte
character string to wide-character string?
Is FdoStringP::Utf8ToUnicode() function recommended to convert
strings?
Cheers
Mateusz Loskot
http://mateusz.loskot.net
To unsubscribe, e-mail: dev-unsubscribe at fdo.osgeo.org
For additional commands, e-mail: dev-help at fdo.osgeo.org
More information about the Fdo_dev
