Problem about IFeatureReader & IFeatureReaderImp in Managed FDO
song yafeng-Heman
yfsong at hslcn.com
Tue Sep 5 21:37:48 EDT 2006
Hi everyone.
I met a problem about IFeatureReader when I was writing C# code.
I rewrite the class MyFeatureReader derived from IFeatureReader in C#
which is the same as the class in GmlWriteTest.cpp in unit test of FDO
with the same name.
Then I use XmlFeatureSerializer.XmlSerialize(featureReader,
featureWriter, flags), but always meet errors.
I debug in the mgFdo, find error occurs here (in the red).
[code]
System::Void
NAMESPACE_FDO_XML::XmlFeatureSerializer::XmlSerialize(NAMESPACE_FDO_COMM
ANDS_FEATURE::IFeatureReader* reader,
NAMESPACE_FDO_XML::XmlFeatureWriter* writer,
NAMESPACE_FDO_XML::XmlFeatureFlags* flags)
//The original code.
//EXCEPTION_HANDLER(FdoXmlFeatureSerializer::XmlSerialize(static_cast<NA
MESPACE_FDO_COMMANDS_FEATURE::IFeatureReaderImp*>(reader)->GetImpObj(),
writer->GetImpObj(), flags->GetImpObj()))
//The full code same as the original code
NAMESPACE_FDO_COMMANDS_FEATURE::IFeatureReaderImp* readerImp =
static_cast<NAMESPACE_FDO_COMMANDS_FEATURE::IFeatureReaderImp*>(reader);
GisPtr<FdoIFeatureReader> uReader = readerImp->GetImpObj();
GisPtr<FdoXmlFeatureWriter> uWriter = writer->GetImpObj();
GisPtr<FdoXmlFeatureFlags> uFlags = flags->GetImpObj();
try
FdoXmlFeatureSerializer::XmlSerialize(uReader,
uWriter, uFlags);
catch(GisException* e)
NAMESPACE_COMMON::Exception* mgE =
NAMESPACE_COMMON::Exception::Create(e);
e->Release();
throw mgE;
[/code]
Because the reader is derived from IFearureReader, cast it to a
IFeatureReaderImp is not a right operation. Then use GetImpObj() will
get wrong pointer. This wrong point cause the error later.
Is this a bug or I make some mistakes in my code?
A bit of help would be greatly appreciated.
Thanks
Kino
URL: http://lists.osgeo.org/pipermail/fdo_dev/attachments/20060906/6b2e404e/attachment.html
More information about the Fdo_dev
