[fdo-dev] Building SHP Provider : error
Pierre Dalcourt pierre.dalcourt at autodesk.com
Tue Sep 19 12:09:33 EDT 2006
Hi Ytse,
The message ID "FDO_131_UNSUPPORTED_GEOMETRY_TYPE" is defined in the Fdocore repository at Fdo/Unmanages/Src/Message/FDOMessage.mc .  You need to synchronize to the latest fdocore code, rebuild the fdo.sln, then try building shp again.
Pierre
-----Original Message-----
Sent: September 19, 2006 12:01 PM
To: dev at fdo.osgeo.org
Subject: [fdo-dev] Building SHP Provider : error
Not sure what to do with this error, if anyone can
help, thx in advance
I've built the fdocore first by running build.bat
and then tried to build the fdoshp by running
build.bat -w=shp
Here goes the error
TargetReader:
[...]Providers\SHP\Src\ShpRead\ShpRead.tmp_Release_Win32.vcproj
"Release|Win32"
.\ShapeFile.cpp(1238): error C2065:
'FDO_131_UNSUPPORTED_GEOMETRY_TYPE' : undeclared
identifier
Done building target "Reader" in project
"SHP_temp.sln" -- FAILED.
Then the Target Common fails with loads of errors (but
I guess they're linked somehow)
Thank you for your help
___________________________________________________________________________
Découvrez un nouveau moyen de poser toutes vos questions quelque soit le sujet !
Yahoo! Questions/Réponses pour partager vos connaissances, vos opinions et vos expériences.
http://fr.answers.yahoo.com
To unsubscribe, e-mail: dev-unsubscribe at fdo.osgeo.org
For additional commands, e-mail: dev-help at fdo.osgeo.org
More information about the Fdo_dev mailing list
