[fdo-dev] TestRunner project
Romica Dascalescu
Romica.Dascalescu at autodesk.com
Fri Sep 22 16:54:54 EDT 2006
Hi Mateusz,
I believe you have an old version and you didn't update this file
(Fdo\UnitTest.vcproj) because you have defined __CPPUNIT_MFC_AP in
PreprocessorDefinitions from VC++
Remove __CPPUNIT_MFC_AP or update the file from SVN.
Romy.
-----Original Message-----
From: Mateusz Loskot [mailto:mateusz at loskot.net]
Sent: Friday, September 22, 2006 4:47 PM
To: dev at fdo.osgeo.org
Subject: Re: [fdo-dev] TestRunner project
Greg Boone wrote:
> I cannot reproduce your error in a debug build.
> Can you send me the error message?
Here it is (red line)
http://mateusz.loskot.net/tmp/testrunnerlib-not-found.png
> Are you building Debug or Release?
Both, I tested both build configurations:
setenvironment.bat
1.
build_thirdparty.bat -c=debug
build.bat -c=debug
1. build_thirdparty.bat
build.bat
Note, I build from command line (not IDE) and I don't have any env
variables set, besides those configured by setenvironment.bat script.
Cheers
Mateusz Loskot
To unsubscribe, e-mail: dev-unsubscribe at fdo.osgeo.org
For additional commands, e-mail: dev-help at fdo.osgeo.org
More information about the Fdo_dev
