[fdo-dev] Unit Test reports
Dan Stoica
dan.stoica at autodesk.com
Mon Sep 25 13:17:46 EDT 2006
" SHP provider UT gives me 28 failures"
Can you send me a log file with these errors?
Dan.
-----Original Message-----
From: Mateusz Loskot [mailto:mateusz at loskot.net]
Sent: Monday, September 25, 2006 1:09 PM
To: fdo-dev
Subject: [fdo-dev] Unit Test reports
Is there anything like official FDO Unit Test report where one could
observe results of "official" run of FDO UT?
Everyone can run FDO Unit Tests but the results are not very
usable and meaningful if there is nothing to compare with.
For example, SHP provider UT gives me 28 failures and I have no
idea if these failures are known (fixing in progress) or they fail
only in my environment.
Also, I don't know if I should report these failures as bugs, etc.
I'm looking for something like this:
http://engineering.meta-comm.com/boost-regression/CVS-HEAD/developer/
Cheers
Mateusz Loskot
http://mateusz.loskot.net
To unsubscribe, e-mail: dev-unsubscribe at fdo.osgeo.org
For additional commands, e-mail: dev-help at fdo.osgeo.org
More information about the Fdo_dev
