[fdo-dev] FDO172 & Warning of "build breaker" changes
Pierre Dalcourt
pierre.dalcourt at autodesk.com
Tue Sep 26 11:13:10 EDT 2006
Hi Frank,
This method is used to indicate the theoretical maximum size of data
values that can be read/written using the given provider. I'm not 100%
sure which client(s) will be using these capabilities.
The value "-1" in such capability APIs indicates that there is
theoretically no limit, although in practice there may be a real limit
imposed by several factors (file system size, etc). In the case of SHP
Provider's Blob/Clob size limits, -1 is returned but should be ignored
by the caller because SHP Provider does not support Blobs/Clobs as of
this time.
In the case of a value as large as 2^63 there may not be a significant
difference between returning 2^63 or -1 but if you have an accurate
maximum value it would be best to return it instead of -1.
Pierre
-----Original Message-----
Sent: September 26, 2006 9:34 AM
To: dev at fdo.osgeo.org
Subject: Re: [fdo-dev] FDO172 & Warning of "build breaker" changes
Folks,
On a related point, I'm not sure how to implement
ISChemaCapabilities::GetMaximumDataValueLength().
Is this method just used when creating new fields? I see the shape
provider returns -1 for some field types. Does this imply unlimited
or unsupported?
For my raster provider the upper size of a BLOB is in theory 2^63 or
so. Should I return that?
Best regards,
I set the clouds in motion - turn up | Frank Warmerdam,
warmerdam at pobox.com
and watch the world go round - Rush | President OSGeo,
http://osgeo.org
To unsubscribe, e-mail: dev-unsubscribe at fdo.osgeo.org
For additional commands, e-mail: dev-help at fdo.osgeo.org
More information about the Fdo_dev
