[fdo-dev] using dot '.' in schema element name
Orest Halustchak orest.halustchak at autodesk.com
Fri Sep 29 07:56:20 EDT 2006
Hi Haris,
Dot and colon are reserved and cannot be used for scheme element names.
Colon is used as a delimeter between schema name and class name (e.g.
LandBase:Road) and dot is used for accessing object properties (e.g.
Address.StreetNumber) or for associations.
Thanks,
Orest.
  _____
Sent: Friday, September 29, 2006 7:21 AM
To: dev at fdo.osgeo.org
Subject: [fdo-dev] using dot '.' in schema element name
I am wondering is it possible to allow '.' dot character to be part of
FdoSchemaElement name ?
I realized that '.' is hard coded and used as scope delimiter for
fdoidentifer's but
I think it is important to be able to have class name  like:
'DbSchema.TableName.ColumnName'.
Right now I am using ~ character but more intuitive would be to use '.'
Haris
URL: http://lists.osgeo.org/pipermail/fdo_dev/attachments/20060929/82a0fdee/attachment.html
More information about the Fdo_dev mailing list
