[Fdo_dev] About RDBI's get_gen_id() function
Badreddine Karoui
badreddine.karoui at autodesk.com
Thu Jan 11 09:09:19 EST 2007
We've been committing code for over a week into the 3.2.x branch. As far
as I know everything is ok.
How often you need to change code that is not specific to PostGIS
provider? This particular change seems to be a no-op as far as the other
providers and I'm wondering if this is an isolated an rare event, it
should probably be merged sooner than later into the main branches. We
don't want to end up at one point in the future not being able to
integrate the PostGIS provider because we would not be allowed to make
such a change to other providers.
Badreddine
-----Original Message-----
[mailto:fdo_dev-bounces at lists.osgeo.org] On Behalf Of Mateusz Loskot
Sent: Wednesday, January 10, 2007 11:19 PM
To: fdo_dev
Subject: Re: [Fdo_dev] About RDBI's get_gen_id() function
Greg, Badreddine,
Yes, that's perfectly clear to me that I'm working on my
private branch now, so all changes on other components than PostGIS
provider go there too and should be reviewed.
Also, I've not yet started to use the new FDO repositories after the
migration, as I'd prefer to wait until everything works well.
Do you recommend to start committing now (to my private branch) ?
Mat
Greg Boone wrote:
> Any changes would have to go into the PostGIS branch only. Once the
> change has been reviewed it can be integrated into the GenericRDBMS
> trunk. This change should not be integrated into the 3.2.x branch.
> From: fdo_dev-bounces at lists.osgeo.org
> [mailto:fdo_dev-bounces at lists.osgeo.org] On Behalf Of Badreddine
Karoui
> Sent: Wednesday, January 10, 2007 12:32 PM
> To: fdo_dev
> Subject: RE: [Fdo_dev] About RDBI's get_gen_id() function
> Go ahead. But can you hold off changing subversion until tomorrow?
> Badreddine
> Sent: Wednesday, January 10, 2007 12:17 PM
> To: fdo_dev
> Badreddine Karoui wrote:
>> Hi,
>> The GDBI/RDBI interface is not cast in stone. Option 1 seems the
>> reasonable solution to me.
>> MySql driver just have to be fixed up in this
>> case and no need for the kludge of option 2.
> OK, so I'm waiting for answer on my question who is going to fix it.
> I can do it too.
> Cheers
Mateusz Loskot
http://mateusz.loskot.net
Fdo_dev mailing list
Fdo_dev at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/fdo_dev
More information about the Fdo_dev
