[fdo][FDO107][New] SDF: FdoISelect command fails to return an inserted feature
Jack Lee jack.lee at autodesk.com
Wed Aug 2 12:57:11 EDT 2006
You can view the artifact detail at the following URL:
    https://fdo.osgeo.org/servlets/Scarab/id/FDO107
Type
 Defect
Artifact ID
 FDO107 (SDF: FdoISelect command fails to return an inserted feature)
Reported by
 Jack Lee
 jacklee (jack.lee at autodesk.com)
New artifact details:
- Subcomponent set to new value
  FEATURE COMMANDS
- Artifact Status set to new value
  New
- Description set to new value
- Component set to new value
  SDF
- Artifact created
- Summary set to new value
- Operating system set to new value
  All
- Platform set to new value
  All
- Steps to Reproduce set to new value
  Here's what's happening...
- a new SDF is created
- it reads the first entity (from the input SDF) and adds it to the new SDF
- it reads the second entity, and tries to add it to the new SDF
- since it has an identical key -- an exception results
- so we create an FdoISelect command to retrieve the first entity just added (to merge with the second entity)
- BUT the FdoISelect command is unable to return the first entity!!!
This message was automatically generated by Project Tracker.
More information about the Fdo_issues mailing list
