[fdo][FDO108][New] SDF: SDF files larger than 3GB cannot be accessed on Linux
Jack Lee
jack.lee at autodesk.com
Wed Aug 2 14:42:55 EDT 2006
You can view the artifact detail at the following URL:
https://fdo.osgeo.org/servlets/Scarab/id/FDO108
Type
Defect
Artifact ID
FDO108 (SDF: SDF files larger than 3GB cannot be accessed on Linux)
Reported by
Jack Lee
jacklee (jack.lee at autodesk.com)
New artifact details:
- Summary set to new value
- Artifact Status set to new value
New
- Component set to new value
SDF
- Artifact created
- Description set to new value
Create an SDF 3.0 which is larger than 3GB on Windows. Use the same file with MapGuide on Linux. The following error is generated:
An exception occurred in FDO component. SDFPROVIDER_50_NONEXISTING_FILE Exception occurred in method MgFdoConnectionManager.Open at line 832 in file FdoConnectionManager.cpp
This message was automatically generated by Project Tracker.
More information about the Fdo_issues
