[fdo][FDO112][New] Fix FDO Build Issues
Greg Boone
greg.boone at autodesk.com
Thu Aug 3 14:28:29 EDT 2006
You can view the artifact detail at the following URL:
https://fdo.osgeo.org/servlets/Scarab/id/FDO112
Type
Task
Artifact ID
FDO112 (Fix FDO Build Issues)
Reported by
Greg Boone
gregboone (greg.boone at autodesk.com)
New artifact details:
- Priority set to new value
P1
- Artifact created
- Summary set to new value
- Task Priority set to new value
High
- Target milestone set to new value
3.2.0
- Description set to new value
This artifact is an open-ended artifact used to fix issues that are causing FDO builds to fail.
- Need By Date set to new value
2006-12-29
- Planned Start Date set to new value
2006-08-03
- Artifact Status set to new value
New
- Actual Start Date set to new value
2006-08-03
This message was automatically generated by Project Tracker.
More information about the Fdo_issues
