[fdo][FDO113][New] fdordbms/nls/linux/en_US/fdordbmsmsg.cat: No such file
Mateusz Loskot mateusz at loskot.net
Thu Aug 3 14:31:15 EDT 2006
You can view the artifact detail at the following URL:
    https://fdo.osgeo.org/servlets/Scarab/id/FDO113
Type
 Defect
Artifact ID
 FDO113 (fdordbms/nls/linux/en_US/fdordbmsmsg.cat: No such file)
Reported by
 Mateusz Loskot
 mloskot (mateusz at loskot.net)
New artifact details:
- Description set to new value
  make fails when trying to build current (today) SVN version of fdordbms.
As I see, the problem is with Nls/Makefile.am.
This makefile uses lower-case directory names, but FDO projects use camel-case naming convention of files and directories (I was told aboutit by Greg Boone).
- Platform set to new value
  PC
- Steps to Reproduce set to new value
  0. source fdocore/setenvironment.sh (according to building instructions)
1. Build fdocore
2. svn update or checkout of fdordbms
3. cd directory wich fdordbms sources
4. run ./build_linus.sh
5. Here is the output:
(see attached file)
- Artifact created
- Summary set to new value
- Defect Severity set to new value
  Critical
- Operating system set to new value
  Linux
- OS Distribution and Version set to new value
  Ubunbu 6.06
- Artifact Status set to new value
  New
- Added file attachment
  fdordbms-build-output.txt
- Component set to new value
  RDBMS
- Developer Notes set to new value
  Nls/Makefile.am includes lower-case name of 'nls' directory:
line 5: CATDIR = nls/linux/en_US
- Subcomponent set to new value
  BUILD & INSTALL
This message was automatically generated by Project Tracker.
More information about the Fdo_issues mailing list
