[fdo][FDO113][Modified] fdordbms/nls/linux/en_US/fdordbmsmsg.cat: No such file
Greg Boone
greg.boone at autodesk.com
Fri Aug 4 14:35:51 EDT 2006
You can view the artifact detail at the following URL:
https://fdo.osgeo.org/servlets/Scarab/id/FDO113
Type:
Defect
Artifact ID:
FDO113 (fdordbms/nls/linux/en_US/fdordbmsmsg.cat: No such file)
Modified by:
Greg Boone
gregboone (greg.boone at autodesk.com)
The following modifications were made to this artifact:
-- Build set to new value:
G012
-- Artifact Status changed:
Old value:
New
New value:
Resolved
-- Defect Resolution set to new value:
Not Reproducible
-- Status Explanation set to new value:
No Defect found. Issue was resolved by performing a full rebuild.
-- Resolution Description set to new value:
-- Priority set to new value:
P1
-- Target milestone set to new value:
3.2.0
This message was automatically generated by Project Tracker.
More information about the Fdo_issues
