[fdo][FDO116][New] Wrong shell prolog in Thirdparty.sh
Mateusz Loskot
mateusz at loskot.net
Sun Aug 6 13:02:32 EDT 2006
You can view the artifact detail at the following URL:
https://fdo.osgeo.org/servlets/Scarab/id/FDO116
Type
Defect
Artifact ID
FDO116 (Wrong shell prolog in Thirdparty.sh)
Reported by
Mateusz Loskot
mloskot (mateusz at loskot.net)
New artifact details:
- Description set to new value
When running ./build_thirdparty.sh script on fresh sandbox of fdocore, I'm getting following error:
config.status: creating Utilities/SchemaMgr/Src/Sm/Ph/Rd/Makefile
config.status: executing depfiles commands
./build_thirdparty.sh: ./Thirdparty.sh: /bin/csh: bad interpreter: No such file or directory
make[1]: Entering directory `/home/mloskot/dev/fdo/fdocore/_svn/fdocore/Thirdparty'
make[1]: *** No rule to make target `apache/xml-xalan/c/lib/libxalan-c.so.17.0', needed by `all-am'. Stop.
make[1]: Leaving directory `/home/mloskot/dev/fdo/fdocore/_svn/fdocore/Thirdparty'
make: *** [install-recursive] Error 1
- Platform set to new value
PC
- Subcomponent set to new value
BUILD & INSTALL
- Artifact Status set to new value
New
- Artifact created
- Component set to new value
- OS Distribution and Version set to new value
Ubuntu 6.06
- Steps to Reproduce set to new value
0. Assumption: You don't have 'csh' interpreter installed in your system
1. Checkout fdocore sources
2. source setenvironment.sh script (. ./setenvironment.sh)
3. run ./build_thirdparty.sh
- Defect Severity set to new value
High
- Operating system set to new value
Linux
- Summary set to new value
This message was automatically generated by Project Tracker.
More information about the Fdo_issues
