[fdo][FDO122][New] Fix defect #785229 (II)
Dan Stoica dan.stoica at autodesk.com
Tue Aug 15 17:55:06 EDT 2006
You can view the artifact detail at the following URL:
    https://fdo.osgeo.org/servlets/Scarab/id/FDO122
Type
 Defect
Artifact ID
 FDO122 (Fix defect #785229 (II))
Reported by
 Dan Stoica
 danstoica (dan.stoica at autodesk.com)
New artifact details:
- Summary set to new value
- Description set to new value
  [Ported from RELIANT, R068-DS1]
Defect description: SHP: Ceil and Floor functions causes crash
In addition to previous R060-DS1 submission which dealt with a valid use case:
- fixed a wrongly formatted NLS exception message which affected also Upper/Lower functions.
- factored out Ceil/Floor processing.
- allow Ceil/Floor to take Int32 and Int16 arguments, in order to be consistent with native RDBMS functions.
- Artifact Status set to new value
  New
- Artifact created
This message was automatically generated by Project Tracker.
More information about the Fdo_issues mailing list
