[fdo][FDO124][New] SDF Schema Edit
Brent Robinson
brent.robinson at autodesk.com
Thu Aug 17 14:50:25 EDT 2006
You can view the artifact detail at the following URL:
https://fdo.osgeo.org/servlets/Scarab/id/FDO124
Type
Enhancement
Artifact ID
FDO124 (SDF Schema Edit)
Reported by
Brent Robinson
brentrobinson (brent.robinson at autodesk.com)
New artifact details:
- Artifact created
- Description set to new value
Currently, the SDF provider is limited to a single ApplySchema command execution. Once a feature schema has been applied to an SDF provider datastore, it is not possible to modify this feature schema. This was not a requirement but the result of scope limitation in it’s first release.
The purpose of this artifact is to lift this restriction and allow some limited schema modifications:
- add class definition to existing feature schema
- delete a class definition
- add a property to an existing class definition
- modify the GeometryProperty for a feature class
- delete a property
- Summary set to new value
SDF Schema Edit
- Target milestone set to new value
3.2.0
- Artifact Status set to new value
New
- Priority set to new value
P2
This message was automatically generated by Project Tracker.
More information about the Fdo_issues
