[fdo][FDO124][Modified] SDF Schema Edit
Brent Robinson
brent.robinson at autodesk.com
Mon Aug 21 08:19:35 EDT 2006
You can view the artifact detail at the following URL:
https://fdo.osgeo.org/servlets/Scarab/id/FDO124
Type:
Enhancement
Artifact ID:
FDO124 (SDF Schema Edit)
Modified by:
Brent Robinson
brentrobinson (brent.robinson at autodesk.com)
The following modifications were made to this artifact:
Added following comment to artifact::
Automated Comment. Version control commit message.
FDO124 - Phase I (FDO Common changes)
Enhanced schema merging code, written for XML document handling, to handle general schema merges with or without element states.
Added
File: trunk/Fdo/Unmanaged/Inc/Common/Context.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Unmanaged/Inc/Common/Context.h?view=auto&rev=317
File: trunk/Fdo/Unmanaged/Inc/Fdo/Schema/MergeContext.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Unmanaged/Inc/Fdo/Schema/MergeContext.h?view=auto&rev=317
File: trunk/Fdo/Unmanaged/Src/Common/Context.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Unmanaged/Src/Common/Context.cpp?view=auto&rev=317
File: trunk/Fdo/Unmanaged/Src/Fdo/Schema/MergeContext.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Unmanaged/Src/Fdo/Schema/MergeContext.cpp?view=auto&rev=317
Modified
File: trunk/Fdo/UnitTest/SchemaTest.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/UnitTest/SchemaTest.cpp?view=diff&rev=317&p1=trunk/Fdo/UnitTest/SchemaTest.cpp&r1=316&p2=trunk/Fdo/UnitTest/SchemaTest.cpp&r2=317
File: trunk/Fdo/UnitTest/UnitTest.vcproj https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/UnitTest/UnitTest.vcproj?view=diff&rev=317&p1=trunk/Fdo/UnitTest/UnitTest.vcproj&r1=316&p2=trunk/Fdo/UnitTest/UnitTest.vcproj&r2=317
File: trunk/Fdo/UnitTest/schema_merge2a_master.txt https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/UnitTest/schema_merge2a_master.txt?view=diff&rev=317&p1=trunk/Fdo/UnitTest/schema_merge2a_master.txt&r1=316&p2=trunk/Fdo/UnitTest/schema_merge2a_master.txt&r2=317
File: trunk/Fdo/UnitTest/schema_merge2b_master.txt https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/UnitTest/schema_merge2b_master.txt?view=diff&rev=317&p1=trunk/Fdo/UnitTest/schema_merge2b_master.txt&r1=316&p2=trunk/Fdo/UnitTest/schema_merge2b_master.txt&r2=317
File: trunk/Fdo/UnitTest/schema_refs_err_master.txt https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/UnitTest/schema_refs_err_master.txt?view=diff&rev=317&p1=trunk/Fdo/UnitTest/schema_refs_err_master.txt&r1=316&p2=trunk/Fdo/UnitTest/schema_refs_err_master.txt&r2=317
File: trunk/Fdo/Unmanaged/Common.vcproj https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Unmanaged/Common.vcproj?view=diff&rev=317&p1=trunk/Fdo/Unmanaged/Common.vcproj&r1=316&p2=trunk/Fdo/Unmanaged/Common.vcproj&r2=317
File: trunk/Fdo/Unmanaged/Fdo.vcproj https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Unmanaged/Fdo.vcproj?view=diff&rev=317&p1=trunk/Fdo/Unmanaged/Fdo.vcproj&r1=316&p2=trunk/Fdo/Unmanaged/Fdo.vcproj&r2=317
File: trunk/Fdo/Unmanaged/Inc/Common/Xml/SaxContext.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Unmanaged/Inc/Common/Xml/SaxContext.h?view=diff&rev=317&p1=trunk/Fdo/Unmanaged/Inc/Common/Xml/SaxContext.h&r1=316&p2=trunk/Fdo/Unmanaged/Inc/Common/Xml/SaxContext.h&r2=317
File: trunk/Fdo/Unmanaged/Inc/Fdo.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Unmanaged/Inc/Fdo.h?view=diff&rev=317&p1=trunk/Fdo/Unmanaged/Inc/Fdo.h&r1=316&p2=trunk/Fdo/Unmanaged/Inc/Fdo.h&r2=317
File: trunk/Fdo/Unmanaged/Inc/Fdo/Raster/RasterDataModel.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Unmanaged/Inc/Fdo/Raster/RasterDataModel.h?view=diff&rev=317&p1=trunk/Fdo/Unmanaged/Inc/Fdo/Raster/RasterDataModel.h&r1=316&p2=trunk/Fdo/Unmanaged/Inc/Fdo/Raster/RasterDataModel.h&r2=317
File: trunk/Fdo/Unmanaged/Inc/Fdo/Schema/AssociationPropertyDefinition.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Unmanaged/Inc/Fdo/Schema/AssociationPropertyDefinition.h?view=diff&rev=317&p1=trunk/Fdo/Unmanaged/Inc/Fdo/Schema/AssociationPropertyDefinition.h&r1=316&p2=trunk/Fdo/Unmanaged/Inc/Fdo/Schema/AssociationPropertyDefinition.h&r2=317
File: trunk/Fdo/Unmanaged/Inc/Fdo/Schema/ClassDefinition.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Unmanaged/Inc/Fdo/Schema/ClassDefinition.h?view=diff&rev=317&p1=trunk/Fdo/Unmanaged/Inc/Fdo/Schema/ClassDefinition.h&r1=316&p2=trunk/Fdo/Unmanaged/Inc/Fdo/Schema/ClassDefinition.h&r2=317
File: trunk/Fdo/Unmanaged/Inc/Fdo/Schema/DataPropertyDefinition.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Unmanaged/Inc/Fdo/Schema/DataPropertyDefinition.h?view=diff&rev=317&p1=trunk/Fdo/Unmanaged/Inc/Fdo/Schema/DataPropertyDefinition.h&r1=316&p2=trunk/Fdo/Unmanaged/Inc/Fdo/Schema/DataPropertyDefinition.h&r2=317
File: trunk/Fdo/Unmanaged/Inc/Fdo/Schema/FeatureClass.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Unmanaged/Inc/Fdo/Schema/FeatureClass.h?view=diff&rev=317&p1=trunk/Fdo/Unmanaged/Inc/Fdo/Schema/FeatureClass.h&r1=316&p2=trunk/Fdo/Unmanaged/Inc/Fdo/Schema/FeatureClass.h&r2=317
File: trunk/Fdo/Unmanaged/Inc/Fdo/Schema/FeatureSchema.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Unmanaged/Inc/Fdo/Schema/FeatureSchema.h?view=diff&rev=317&p1=trunk/Fdo/Unmanaged/Inc/Fdo/Schema/FeatureSchema.h&r1=316&p2=trunk/Fdo/Unmanaged/Inc/Fdo/Schema/FeatureSchema.h&r2=317
File: trunk/Fdo/Unmanaged/Inc/Fdo/Schema/GeometricPropertyDefinition.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Unmanaged/Inc/Fdo/Schema/GeometricPropertyDefinition.h?view=diff&rev=317&p1=trunk/Fdo/Unmanaged/Inc/Fdo/Schema/GeometricPropertyDefinition.h&r1=316&p2=trunk/Fdo/Unmanaged/Inc/Fdo/Schema/GeometricPropertyDefinition.h&r2=317
File: trunk/Fdo/Unmanaged/Inc/Fdo/Schema/NetworkClass.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Unmanaged/Inc/Fdo/Schema/NetworkClass.h?view=diff&rev=317&p1=trunk/Fdo/Unmanaged/Inc/Fdo/Schema/NetworkClass.h&r1=316&p2=trunk/Fdo/Unmanaged/Inc/Fdo/Schema/NetworkClass.h&r2=317
File: trunk/Fdo/Unmanaged/Inc/Fdo/Schema/NetworkFeatureClass.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Unmanaged/Inc/Fdo/Schema/NetworkFeatureClass.h?view=diff&rev=317&p1=trunk/Fdo/Unmanaged/Inc/Fdo/Schema/NetworkFeatureClass.h&r1=316&p2=trunk/Fdo/Unmanaged/Inc/Fdo/Schema/NetworkFeatureClass.h&r2=317
File: trunk/Fdo/Unmanaged/Inc/Fdo/Schema/NetworkLayerClass.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Unmanaged/Inc/Fdo/Schema/NetworkLayerClass.h?view=diff&rev=317&p1=trunk/Fdo/Unmanaged/Inc/Fdo/Schema/NetworkLayerClass.h&r1=316&p2=trunk/Fdo/Unmanaged/Inc/Fdo/Schema/NetworkLayerClass.h&r2=317
File: trunk/Fdo/Unmanaged/Inc/Fdo/Schema/NetworkLinkFeatureClass.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Unmanaged/Inc/Fdo/Schema/NetworkLinkFeatureClass.h?view=diff&rev=317&p1=trunk/Fdo/Unmanaged/Inc/Fdo/Schema/NetworkLinkFeatureClass.h&r1=316&p2=trunk/Fdo/Unmanaged/Inc/Fdo/Schema/NetworkLinkFeatureClass.h&r2=317
File: trunk/Fdo/Unmanaged/Inc/Fdo/Schema/NetworkNodeFeatureClass.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Unmanaged/Inc/Fdo/Schema/NetworkNodeFeatureClass.h?view=diff&rev=317&p1=trunk/Fdo/Unmanaged/Inc/Fdo/Schema/NetworkNodeFeatureClass.h&r1=316&p2=trunk/Fdo/Unmanaged/Inc/Fdo/Schema/NetworkNodeFeatureClass.h&r2=317
File: trunk/Fdo/Unmanaged/Inc/Fdo/Schema/ObjectPropertyDefinition.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Unmanaged/Inc/Fdo/Schema/ObjectPropertyDefinition.h?view=diff&rev=317&p1=trunk/Fdo/Unmanaged/Inc/Fdo/Schema/ObjectPropertyDefinition.h&r1=316&p2=trunk/Fdo/Unmanaged/Inc/Fdo/Schema/ObjectPropertyDefinition.h&r2=317
File: trunk/Fdo/Unmanaged/Inc/Fdo/Schema/PropertyDefinition.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Unmanaged/Inc/Fdo/Schema/PropertyDefinition.h?view=diff&rev=317&p1=trunk/Fdo/Unmanaged/Inc/Fdo/Schema/PropertyDefinition.h&r1=316&p2=trunk/Fdo/Unmanaged/Inc/Fdo/Schema/PropertyDefinition.h&r2=317
File: trunk/Fdo/Unmanaged/Inc/Fdo/Schema/PropertyValueConstraint.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Unmanaged/Inc/Fdo/Schema/PropertyValueConstraint.h?view=diff&rev=317&p1=trunk/Fdo/Unmanaged/Inc/Fdo/Schema/PropertyValueConstraint.h&r1=316&p2=trunk/Fdo/Unmanaged/Inc/Fdo/Schema/PropertyValueConstraint.h&r2=317
File: trunk/Fdo/Unmanaged/Inc/Fdo/Schema/PropertyValueConstraintList.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Unmanaged/Inc/Fdo/Schema/PropertyValueConstraintList.h?view=diff&rev=317&p1=trunk/Fdo/Unmanaged/Inc/Fdo/Schema/PropertyValueConstraintList.h&r1=316&p2=trunk/Fdo/Unmanaged/Inc/Fdo/Schema/PropertyValueConstraintList.h&r2=317
File: trunk/Fdo/Unmanaged/Inc/Fdo/Schema/PropertyValueConstraintRange.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Unmanaged/Inc/Fdo/Schema/PropertyValueConstraintRange.h?view=diff&rev=317&p1=trunk/Fdo/Unmanaged/Inc/Fdo/Schema/PropertyValueConstraintRange.h&r1=316&p2=trunk/Fdo/Unmanaged/Inc/Fdo/Schema/PropertyValueConstraintRange.h&r2=317
File: trunk/Fdo/Unmanaged/Inc/Fdo/Schema/RasterPropertyDefinition.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Unmanaged/Inc/Fdo/Schema/RasterPropertyDefinition.h?view=diff&rev=317&p1=trunk/Fdo/Unmanaged/Inc/Fdo/Schema/RasterPropertyDefinition.h&r1=316&p2=trunk/Fdo/Unmanaged/Inc/Fdo/Schema/RasterPropertyDefinition.h&r2=317
File: trunk/Fdo/Unmanaged/Inc/Fdo/Schema/SchemaElement.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Unmanaged/Inc/Fdo/Schema/SchemaElement.h?view=diff&rev=317&p1=trunk/Fdo/Unmanaged/Inc/Fdo/Schema/SchemaElement.h&r1=316&p2=trunk/Fdo/Unmanaged/Inc/Fdo/Schema/SchemaElement.h&r2=317
File: trunk/Fdo/Unmanaged/Inc/FdoCommon.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Unmanaged/Inc/FdoCommon.h?view=diff&rev=317&p1=trunk/Fdo/Unmanaged/Inc/FdoCommon.h&r1=316&p2=trunk/Fdo/Unmanaged/Inc/FdoCommon.h&r2=317
File: trunk/Fdo/Unmanaged/Src/Common/Makefile.am https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Unmanaged/Src/Common/Makefile.am?view=diff&rev=317&p1=trunk/Fdo/Unmanaged/Src/Common/Makefile.am&r1=316&p2=trunk/Fdo/Unmanaged/Src/Common/Makefile.am&r2=317
File: trunk/Fdo/Unmanaged/Src/Common/Xml/SaxContext.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Unmanaged/Src/Common/Xml/SaxContext.cpp?view=diff&rev=317&p1=trunk/Fdo/Unmanaged/Src/Common/Xml/SaxContext.cpp&r1=316&p2=trunk/Fdo/Unmanaged/Src/Common/Xml/SaxContext.cpp&r2=317
File: trunk/Fdo/Unmanaged/Src/Fdo/Makefile.am https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Unmanaged/Src/Fdo/Makefile.am?view=diff&rev=317&p1=trunk/Fdo/Unmanaged/Src/Fdo/Makefile.am&r1=316&p2=trunk/Fdo/Unmanaged/Src/Fdo/Makefile.am&r2=317
File: trunk/Fdo/Unmanaged/Src/Fdo/Raster/RasterDataModel.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Unmanaged/Src/Fdo/Raster/RasterDataModel.cpp?view=diff&rev=317&p1=trunk/Fdo/Unmanaged/Src/Fdo/Raster/RasterDataModel.cpp&r1=316&p2=trunk/Fdo/Unmanaged/Src/Fdo/Raster/RasterDataModel.cpp&r2=317
File: trunk/Fdo/Unmanaged/Src/Fdo/Schema/AssociationPropertyDefinition.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Unmanaged/Src/Fdo/Schema/AssociationPropertyDefinition.cpp?view=diff&rev=317&p1=trunk/Fdo/Unmanaged/Src/Fdo/Schema/AssociationPropertyDefinition.cpp&r1=316&p2=trunk/Fdo/Unmanaged/Src/Fdo/Schema/AssociationPropertyDefinition.cpp&r2=317
File: trunk/Fdo/Unmanaged/Src/Fdo/Schema/ClassDefinition.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Unmanaged/Src/Fdo/Schema/ClassDefinition.cpp?view=diff&rev=317&p1=trunk/Fdo/Unmanaged/Src/Fdo/Schema/ClassDefinition.cpp&r1=316&p2=trunk/Fdo/Unmanaged/Src/Fdo/Schema/ClassDefinition.cpp&r2=317
File: trunk/Fdo/Unmanaged/Src/Fdo/Schema/DataPropertyDefinition.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Unmanaged/Src/Fdo/Schema/DataPropertyDefinition.cpp?view=diff&rev=317&p1=trunk/Fdo/Unmanaged/Src/Fdo/Schema/DataPropertyDefinition.cpp&r1=316&p2=trunk/Fdo/Unmanaged/Src/Fdo/Schema/DataPropertyDefinition.cpp&r2=317
File: trunk/Fdo/Unmanaged/Src/Fdo/Schema/FeatureClass.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Unmanaged/Src/Fdo/Schema/FeatureClass.cpp?view=diff&rev=317&p1=trunk/Fdo/Unmanaged/Src/Fdo/Schema/FeatureClass.cpp&r1=316&p2=trunk/Fdo/Unmanaged/Src/Fdo/Schema/FeatureClass.cpp&r2=317
File: trunk/Fdo/Unmanaged/Src/Fdo/Schema/FeatureSchema.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Unmanaged/Src/Fdo/Schema/FeatureSchema.cpp?view=diff&rev=317&p1=trunk/Fdo/Unmanaged/Src/Fdo/Schema/FeatureSchema.cpp&r1=316&p2=trunk/Fdo/Unmanaged/Src/Fdo/Schema/FeatureSchema.cpp&r2=317
File: trunk/Fdo/Unmanaged/Src/Fdo/Schema/FeatureSchemaCollection.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Unmanaged/Src/Fdo/Schema/FeatureSchemaCollection.cpp?view=diff&rev=317&p1=trunk/Fdo/Unmanaged/Src/Fdo/Schema/FeatureSchemaCollection.cpp&r1=316&p2=trunk/Fdo/Unmanaged/Src/Fdo/Schema/FeatureSchemaCollection.cpp&r2=317
File: trunk/Fdo/Unmanaged/Src/Fdo/Schema/GeometricPropertyDefinition.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Unmanaged/Src/Fdo/Schema/GeometricPropertyDefinition.cpp?view=diff&rev=317&p1=trunk/Fdo/Unmanaged/Src/Fdo/Schema/GeometricPropertyDefinition.cpp&r1=316&p2=trunk/Fdo/Unmanaged/Src/Fdo/Schema/GeometricPropertyDefinition.cpp&r2=317
File: trunk/Fdo/Unmanaged/Src/Fdo/Schema/NetworkClass.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Unmanaged/Src/Fdo/Schema/NetworkClass.cpp?view=diff&rev=317&p1=trunk/Fdo/Unmanaged/Src/Fdo/Schema/NetworkClass.cpp&r1=316&p2=trunk/Fdo/Unmanaged/Src/Fdo/Schema/NetworkClass.cpp&r2=317
File: trunk/Fdo/Unmanaged/Src/Fdo/Schema/NetworkFeatureClass.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Unmanaged/Src/Fdo/Schema/NetworkFeatureClass.cpp?view=diff&rev=317&p1=trunk/Fdo/Unmanaged/Src/Fdo/Schema/NetworkFeatureClass.cpp&r1=316&p2=trunk/Fdo/Unmanaged/Src/Fdo/Schema/NetworkFeatureClass.cpp&r2=317
File: trunk/Fdo/Unmanaged/Src/Fdo/Schema/NetworkLayerClass.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Unmanaged/Src/Fdo/Schema/NetworkLayerClass.cpp?view=diff&rev=317&p1=trunk/Fdo/Unmanaged/Src/Fdo/Schema/NetworkLayerClass.cpp&r1=316&p2=trunk/Fdo/Unmanaged/Src/Fdo/Schema/NetworkLayerClass.cpp&r2=317
File: trunk/Fdo/Unmanaged/Src/Fdo/Schema/NetworkLinkFeatureClass.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Unmanaged/Src/Fdo/Schema/NetworkLinkFeatureClass.cpp?view=diff&rev=317&p1=trunk/Fdo/Unmanaged/Src/Fdo/Schema/NetworkLinkFeatureClass.cpp&r1=316&p2=trunk/Fdo/Unmanaged/Src/Fdo/Schema/NetworkLinkFeatureClass.cpp&r2=317
File: trunk/Fdo/Unmanaged/Src/Fdo/Schema/NetworkNodeFeatureClass.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Unmanaged/Src/Fdo/Schema/NetworkNodeFeatureClass.cpp?view=diff&rev=317&p1=trunk/Fdo/Unmanaged/Src/Fdo/Schema/NetworkNodeFeatureClass.cpp&r1=316&p2=trunk/Fdo/Unmanaged/Src/Fdo/Schema/NetworkNodeFeatureClass.cpp&r2=317
File: trunk/Fdo/Unmanaged/Src/Fdo/Schema/ObjectPropertyDefinition.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Unmanaged/Src/Fdo/Schema/ObjectPropertyDefinition.cpp?view=diff&rev=317&p1=trunk/Fdo/Unmanaged/Src/Fdo/Schema/ObjectPropertyDefinition.cpp&r1=316&p2=trunk/Fdo/Unmanaged/Src/Fdo/Schema/ObjectPropertyDefinition.cpp&r2=317
File: trunk/Fdo/Unmanaged/Src/Fdo/Schema/PropertyDefinition.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Unmanaged/Src/Fdo/Schema/PropertyDefinition.cpp?view=diff&rev=317&p1=trunk/Fdo/Unmanaged/Src/Fdo/Schema/PropertyDefinition.cpp&r1=316&p2=trunk/Fdo/Unmanaged/Src/Fdo/Schema/PropertyDefinition.cpp&r2=317
File: trunk/Fdo/Unmanaged/Src/Fdo/Schema/PropertyValueConstraintList.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Unmanaged/Src/Fdo/Schema/PropertyValueConstraintList.cpp?view=diff&rev=317&p1=trunk/Fdo/Unmanaged/Src/Fdo/Schema/PropertyValueConstraintList.cpp&r1=316&p2=trunk/Fdo/Unmanaged/Src/Fdo/Schema/PropertyValueConstraintList.cpp&r2=317
File: trunk/Fdo/Unmanaged/Src/Fdo/Schema/PropertyValueConstraintRange.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Unmanaged/Src/Fdo/Schema/PropertyValueConstraintRange.cpp?view=diff&rev=317&p1=trunk/Fdo/Unmanaged/Src/Fdo/Schema/PropertyValueConstraintRange.cpp&r1=316&p2=trunk/Fdo/Unmanaged/Src/Fdo/Schema/PropertyValueConstraintRange.cpp&r2=317
File: trunk/Fdo/Unmanaged/Src/Fdo/Schema/RasterPropertyDefinition.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Unmanaged/Src/Fdo/Schema/RasterPropertyDefinition.cpp?view=diff&rev=317&p1=trunk/Fdo/Unmanaged/Src/Fdo/Schema/RasterPropertyDefinition.cpp&r1=316&p2=trunk/Fdo/Unmanaged/Src/Fdo/Schema/RasterPropertyDefinition.cpp&r2=317
File: trunk/Fdo/Unmanaged/Src/Fdo/Schema/SchemaElement.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Unmanaged/Src/Fdo/Schema/SchemaElement.cpp?view=diff&rev=317&p1=trunk/Fdo/Unmanaged/Src/Fdo/Schema/SchemaElement.cpp&r1=316&p2=trunk/Fdo/Unmanaged/Src/Fdo/Schema/SchemaElement.cpp&r2=317
File: trunk/Fdo/Unmanaged/Src/Fdo/Schema/XmlContext.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Unmanaged/Src/Fdo/Schema/XmlContext.cpp?view=diff&rev=317&p1=trunk/Fdo/Unmanaged/Src/Fdo/Schema/XmlContext.cpp&r1=316&p2=trunk/Fdo/Unmanaged/Src/Fdo/Schema/XmlContext.cpp&r2=317
File: trunk/Fdo/Unmanaged/Src/Fdo/Schema/XmlContext.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Unmanaged/Src/Fdo/Schema/XmlContext.h?view=diff&rev=317&p1=trunk/Fdo/Unmanaged/Src/Fdo/Schema/XmlContext.h&r1=316&p2=trunk/Fdo/Unmanaged/Src/Fdo/Schema/XmlContext.h&r2=317
File: trunk/Fdo/Unmanaged/Src/Fdo/Schema/XmlError.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Unmanaged/Src/Fdo/Schema/XmlError.cpp?view=diff&rev=317&p1=trunk/Fdo/Unmanaged/Src/Fdo/Schema/XmlError.cpp&r1=316&p2=trunk/Fdo/Unmanaged/Src/Fdo/Schema/XmlError.cpp&r2=317
File: trunk/Fdo/Unmanaged/Src/Message/FDOMessage.mc https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Unmanaged/Src/Message/FDOMessage.mc?view=diff&rev=317&p1=trunk/Fdo/Unmanaged/Src/Message/FDOMessage.mc&r1=316&p2=trunk/Fdo/Unmanaged/Src/Message/FDOMessage.mc&r2=317
File: trunk/Utilities/SQLiteInterface/SQLiteDataBase.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Utilities/SQLiteInterface/SQLiteDataBase.cpp?view=diff&rev=317&p1=trunk/Utilities/SQLiteInterface/SQLiteDataBase.cpp&r1=316&p2=trunk/Utilities/SQLiteInterface/SQLiteDataBase.cpp&r2=317
File: trunk/Utilities/SQLiteInterface/SQLiteDataBase.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Utilities/SQLiteInterface/SQLiteDataBase.h?view=diff&rev=317&p1=trunk/Utilities/SQLiteInterface/SQLiteDataBase.h&r1=316&p2=trunk/Utilities/SQLiteInterface/SQLiteDataBase.h&r2=317
This message was automatically generated by Project Tracker.
More information about the Fdo_issues
