[fdo][FDO125][New] Fixed 762075.01 FDO NET API: BLOBValue return empty data
Romica Dascalescu romica.dascalescu at autodesk.com
Mon Aug 21 09:49:07 EDT 2006
You can view the artifact detail at the following URL:
    https://fdo.osgeo.org/servlets/Scarab/id/FDO125
Type
 Defect
Artifact ID
 FDO125 (Fixed 762075.01 FDO NET API: BLOBValue return empty data)
Reported by
 Romica Dascalescu
 romicadascalescu (romica.dascalescu at autodesk.com)
New artifact details:
- Artifact created
- Defect Severity set to new value
  Medium
- Submission Reviewed set to new value
  Yes
- Artifact Status set to new value
  New
- Description set to new value
  Update size of byte array after the value is read from the XML reader.
Updated(fixed) the managed unit test testBLOBBase64 to verify the fix.
- Summary set to new value
This message was automatically generated by Project Tracker.
More information about the Fdo_issues mailing list
