[fdo][FDO125][Modified] Fixed 762075.01 FDO NET API: BLOBValue return empty data
Romica Dascalescu
romica.dascalescu at autodesk.com
Mon Aug 21 09:52:26 EDT 2006
You can view the artifact detail at the following URL:
https://fdo.osgeo.org/servlets/Scarab/id/FDO125
Type:
Defect
Artifact ID:
FDO125 (Fixed 762075.01 FDO NET API: BLOBValue return empty data)
Modified by:
Romica Dascalescu
romicadascalescu (romica.dascalescu at autodesk.com)
The following modifications were made to this artifact:
Added following comment to artifact::
Automated Comment. Version control commit message.
FDO125
Modified
File: trunk/Fdo/Managed/UnitTest/mgGmlTest.cs https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/UnitTest/mgGmlTest.cs?view=diff&rev=319&p1=trunk/Fdo/Managed/UnitTest/mgGmlTest.cs&r1=318&p2=trunk/Fdo/Managed/UnitTest/mgGmlTest.cs&r2=319
File: trunk/Fdo/Unmanaged/Src/Fdo/Xml/FeatureReaderImpl.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Unmanaged/Src/Fdo/Xml/FeatureReaderImpl.cpp?view=diff&rev=319&p1=trunk/Fdo/Unmanaged/Src/Fdo/Xml/FeatureReaderImpl.cpp&r1=318&p2=trunk/Fdo/Unmanaged/Src/Fdo/Xml/FeatureReaderImpl.cpp&r2=319
This message was automatically generated by Project Tracker.
More information about the Fdo_issues
