[fdo][FDO124][Modified] SDF Schema Edit
Brent Robinson
brent.robinson at autodesk.com
Wed Aug 23 13:35:00 EDT 2006
You can view the artifact detail at the following URL:
https://fdo.osgeo.org/servlets/Scarab/id/FDO124
Type:
Enhancement
Artifact ID:
FDO124 (SDF Schema Edit)
Modified by:
Brent Robinson
brentrobinson (brent.robinson at autodesk.com)
The following modifications were made to this artifact:
Added following comment to artifact::
Automated Comment. Version control commit message.
FDO124: added svn:eol-style property
Modified
File: trunk/Providers/SDF/Src/UnitTest/apply_schema_test2_master.xml https://fdosdf.osgeo.org/source/browse/fdosdf/trunk/Providers/SDF/Src/UnitTest/apply_schema_test2_master.xml?view=diff&rev=84&p1=trunk/Providers/SDF/Src/UnitTest/apply_schema_test2_master.xml&r1=83&p2=trunk/Providers/SDF/Src/UnitTest/apply_schema_test2_master.xml&r2=84
File: trunk/Providers/SDF/Src/UnitTest/apply_schema_test3_master.xml https://fdosdf.osgeo.org/source/browse/fdosdf/trunk/Providers/SDF/Src/UnitTest/apply_schema_test3_master.xml?view=diff&rev=84&p1=trunk/Providers/SDF/Src/UnitTest/apply_schema_test3_master.xml&r1=83&p2=trunk/Providers/SDF/Src/UnitTest/apply_schema_test3_master.xml&r2=84
This message was automatically generated by Project Tracker.
More information about the Fdo_issues
