[fdo][FDO130][New] GenericRdbms: Fix 785616.01 DataReader handling of geom colu...
Gavin Cramer
gavin.cramer at autodesk.com
Wed Aug 23 15:23:33 EDT 2006
You can view the artifact detail at the following URL:
https://fdo.osgeo.org/servlets/Scarab/id/FDO130
Type
Task
Artifact ID
FDO130 (GenericRdbms: Fix 785616.01 DataReader handling of geom columns (port R067-GC1))
Reported by
Gavin Cramer
gavincramer (gavin.cramer at autodesk.com)
New artifact details:
- Task Priority set to new value
Medium
- Artifact created
- Artifact Status set to new value
New
- Description set to new value
This follows up on G008-GC2 (FDO86), fixing a different execution path that can happen
when processing a DataReader. Two things needed fixing:
1. Column-to-Property mapping needed more logic to handle properties with
multiple columns (ODBC or SqlServer).
2. Some old code needed removal. It wrongly assumed that any column named
"REVISIONNUMBER" (case-insensitive) should be mapped to a property
"RevisionNumber".
TESTING PERFORMED:
UnitTest (Odbc, SqlServer, MySql)
- Summary set to new value
This message was automatically generated by Project Tracker.
More information about the Fdo_issues
