[fdo][FDO134][New] GenericRdbms: Fix 814052.02 Config with no identity property...
Gavin Cramer
gavin.cramer at autodesk.com
Thu Aug 24 14:34:59 EDT 2006
You can view the artifact detail at the following URL:
https://fdo.osgeo.org/servlets/Scarab/id/FDO134
Type
Task
Artifact ID
FDO134 (GenericRdbms: Fix 814052.02 Config with no identity property (port R068-GC1))
Reported by
Gavin Cramer
gavincramer (gavin.cramer at autodesk.com)
New artifact details:
- Artifact created
- Artifact Status set to new value
New
- Task Priority set to new value
Medium
- Description set to new value
This fixes a problem present since R042-BR3. If a configuration file is in use,
and no identifier property is given for a class, attempting to use the class
results in a "Table does not exist for class..." exception. This would
typically happen after reverse-engineering a table with no primary key and then
generating a configuration document programmatically, as Map and MapGuide do.
The issue affects all providers that use Schema Manager. Note: in the original
Reliant code, the fix was only applied to the ODBC Provider to be more
conservative. This port to Granite applies to to all GenericRdbms providers.
- Summary set to new value
This message was automatically generated by Project Tracker.
More information about the Fdo_issues
