[fdo][FDO134][Modified] GenericRdbms: Fix 814052.02 Config with no identity property...
Gavin Cramer
gavin.cramer at autodesk.com
Thu Aug 24 15:17:36 EDT 2006
You can view the artifact detail at the following URL:
https://fdo.osgeo.org/servlets/Scarab/id/FDO134
Type:
Task
Artifact ID:
FDO134 (GenericRdbms: Fix 814052.02 Config with no identity property (port R068-GC1))
Modified by:
Gavin Cramer
gavincramer (gavin.cramer at autodesk.com)
The following modifications were made to this artifact:
-- Task Resolution set to new value:
Submitted
This message was automatically generated by Project Tracker.
More information about the Fdo_issues
