[fdo][FDO133][Modified] Provider implementation not using cursors correctly
Barbara Zoladek barbara.zoladek at autodesk.com
Fri Aug 25 09:54:00 EDT 2006
You can view the artifact detail at the following URL:
    https://fdo.osgeo.org/servlets/Scarab/id/FDO133
Type:
Defect
Artifact ID:
FDO133 (Provider implementation not using cursors correctly)
Modified by:
Barbara Zoladek
barbarazoladek (barbara.zoladek at autodesk.com)
The following modifications were made to this artifact:
Added following comment to artifact::
Automated Comment.  Version control commit message.
FDO133
Modified
File: trunk/Providers/GenericRdbms/Inc/Rdbi/methods.h https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Inc/Rdbi/methods.h?view=diff&rev=158&p1=trunk/Providers/GenericRdbms/Inc/Rdbi/methods.h&r1=157&p2=trunk/Providers/GenericRdbms/Inc/Rdbi/methods.h&r2=158
File: trunk/Providers/GenericRdbms/Src/MySQL/Driver/rdbi_init.c https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/MySQL/Driver/rdbi_init.c?view=diff&rev=158&p1=trunk/Providers/GenericRdbms/Src/MySQL/Driver/rdbi_init.c&r1=157&p2=trunk/Providers/GenericRdbms/Src/MySQL/Driver/rdbi_init.c&r2=158
File: trunk/Providers/GenericRdbms/Src/ODBCDriver/Makefile.am https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/ODBCDriver/Makefile.am?view=diff&rev=158&p1=trunk/Providers/GenericRdbms/Src/ODBCDriver/Makefile.am&r1=157&p2=trunk/Providers/GenericRdbms/Src/ODBCDriver/Makefile.am&r2=158
File: trunk/Providers/GenericRdbms/Src/ODBCDriver/odbcdr.vcproj https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/ODBCDriver/odbcdr.vcproj?view=diff&rev=158&p1=trunk/Providers/GenericRdbms/Src/ODBCDriver/odbcdr.vcproj&r1=157&p2=trunk/Providers/GenericRdbms/Src/ODBCDriver/odbcdr.vcproj&r2=158
File: trunk/Providers/GenericRdbms/Src/ODBCDriver/proto_p.h https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/ODBCDriver/proto_p.h?view=diff&rev=158&p1=trunk/Providers/GenericRdbms/Src/ODBCDriver/proto_p.h&r1=157&p2=trunk/Providers/GenericRdbms/Src/ODBCDriver/proto_p.h&r2=158
File: trunk/Providers/GenericRdbms/Src/ODBCDriver/rdbi_init.c https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/ODBCDriver/rdbi_init.c?view=diff&rev=158&p1=trunk/Providers/GenericRdbms/Src/ODBCDriver/rdbi_init.c&r1=157&p2=trunk/Providers/GenericRdbms/Src/ODBCDriver/rdbi_init.c&r2=158
File: trunk/Providers/GenericRdbms/Src/Rdbi/end_select.c https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/Rdbi/end_select.c?view=diff&rev=158&p1=trunk/Providers/GenericRdbms/Src/Rdbi/end_select.c&r1=157&p2=trunk/Providers/GenericRdbms/Src/Rdbi/end_select.c&r2=158
File: trunk/Providers/GenericRdbms/Src/SchemaMgr/Ph/Mgr.cpp https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/SchemaMgr/Ph/Mgr.cpp?view=diff&rev=158&p1=trunk/Providers/GenericRdbms/Src/SchemaMgr/Ph/Mgr.cpp&r1=157&p2=trunk/Providers/GenericRdbms/Src/SchemaMgr/Ph/Mgr.cpp&r2=158
File: trunk/Providers/GenericRdbms/Src/SchemaMgr/Ph/Mgr.h https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/SchemaMgr/Ph/Mgr.h?view=diff&rev=158&p1=trunk/Providers/GenericRdbms/Src/SchemaMgr/Ph/Mgr.h&r1=157&p2=trunk/Providers/GenericRdbms/Src/SchemaMgr/Ph/Mgr.h&r2=158
File: trunk/Providers/GenericRdbms/Src/SchemaMgr/Ph/Rd/FieldArray.cpp https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/SchemaMgr/Ph/Rd/FieldArray.cpp?view=diff&rev=158&p1=trunk/Providers/GenericRdbms/Src/SchemaMgr/Ph/Rd/FieldArray.cpp&r1=157&p2=trunk/Providers/GenericRdbms/Src/SchemaMgr/Ph/Rd/FieldArray.cpp&r2=158
File: trunk/Providers/GenericRdbms/Src/SchemaMgr/Ph/Rd/FieldArray.h https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/SchemaMgr/Ph/Rd/FieldArray.h?view=diff&rev=158&p1=trunk/Providers/GenericRdbms/Src/SchemaMgr/Ph/Rd/FieldArray.h&r1=157&p2=trunk/Providers/GenericRdbms/Src/SchemaMgr/Ph/Rd/FieldArray.h&r2=158
File: trunk/Providers/GenericRdbms/Src/SchemaMgr/Ph/Rd/QueryReader.cpp https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/SchemaMgr/Ph/Rd/QueryReader.cpp?view=diff&rev=158&p1=trunk/Providers/GenericRdbms/Src/SchemaMgr/Ph/Rd/QueryReader.cpp&r1=157&p2=trunk/Providers/GenericRdbms/Src/SchemaMgr/Ph/Rd/QueryReader.cpp&r2=158
File: trunk/Providers/GenericRdbms/Src/SchemaMgr/Ph/Rd/QueryReader.h https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/SchemaMgr/Ph/Rd/QueryReader.h?view=diff&rev=158&p1=trunk/Providers/GenericRdbms/Src/SchemaMgr/Ph/Rd/QueryReader.h&r1=157&p2=trunk/Providers/GenericRdbms/Src/SchemaMgr/Ph/Rd/QueryReader.h&r2=158
This message was automatically generated by Project Tracker.
More information about the Fdo_issues mailing list
