[fdo][FDO138][New] Generic RDBMS: Clean the open source initialization files
Romica Dascalescu romica.dascalescu at autodesk.com
Mon Aug 28 09:30:47 EDT 2006
You can view the artifact detail at the following URL:
    https://fdo.osgeo.org/servlets/Scarab/id/FDO138
Type
 Task
Artifact ID
 FDO138 (Generic RDBMS: Clean the open source initialization files)
Reported by
 Romica Dascalescu
 romicadascalescu (romica.dascalescu at autodesk.com)
New artifact details:
- Task Priority set to new value
  Low
- Artifact created
- Description set to new value
  To be able to run:
1.	Generic RDBMS MySql unit tests you must:
  o	Update you MySqlInit.txt file with right values and run the unit test
without specifying an initialize file. Please do not drop this file in
subversion if you choose to modify it!
o	Create your own file e.g. MySqlInitEx.txt with right values and run the unit
test by specifying the initialize file, e.g.:
UnitTestMySql initfiletest=MySqlInitEx.txt
  o	The initialize file (MySqlInit.txt) must contain service, username and
password e.g.:
service=localhost;username=root;password=fdotest;
2.	Generic RDBMS Odbc unit tests you must:
  o	Update you OdbcInit.txt file with right values and run the unit test without
specifying an initialize file. Please do not drop this file in subversion if you
  o	Create your own file e.g. OdbcInitEx.txt with right values and run the unit
UnitTestOdbc initfiletest=OdbcInitEx.txt
  o	The initialize file (OdbcInit.txt) must contain serviceOracle,
usernameOracle, passwordOracle, serviceMySql, usernameMySql, passwordMySql,
serviceSqlServer, passwordSqlServer e.g.:
serviceOracle=otwoxy_r10105a;usernameOracle=romy;passwordOracle=test;
serviceMySql=localhost;usernameMySql=root;passwordMySql=fdotest;
serviceSqlServer=seconds;passwordSqlServer=test;
- Summary set to new value
- Submission Reviewed set to new value
  Yes
- Artifact Status set to new value
  New
This message was automatically generated by Project Tracker.
More information about the Fdo_issues mailing list
