[fdo][FDO139][New] Fix unit tests on Linux after Update Constraints submission ...
Dan Stoica
dan.stoica at autodesk.com
Mon Aug 28 17:49:28 EDT 2006
You can view the artifact detail at the following URL:
https://fdo.osgeo.org/servlets/Scarab/id/FDO139
Type
Defect
Artifact ID
FDO139 (Fix unit tests on Linux after Update Constraints submission (FDO136))
Reported by
Dan Stoica
danstoica (dan.stoica at autodesk.com)
New artifact details:
- Summary set to new value
- Description set to new value
A couple of tests were failing due to changes in FDO136.
- Artifact created
- Artifact Status set to new value
New
This message was automatically generated by Project Tracker.
More information about the Fdo_issues
