[fdo][FDO143][Modified] Fixed defect 784301 SHP: Describe Schema fails on shp files ...
Romica Dascalescu romica.dascalescu at autodesk.com
Tue Aug 29 14:22:42 EDT 2006
You can view the artifact detail at the following URL:
    https://fdo.osgeo.org/servlets/Scarab/id/FDO143
Type:
Defect
Artifact ID:
FDO143 (Fixed defect 784301 SHP: Describe Schema fails on shp files with same named projection but different details of the projection)
Modified by:
Romica Dascalescu
romicadascalescu (romica.dascalescu at autodesk.com)
The following modifications were made to this artifact:
Added following comment to artifact::
Automated Comment.  Version control commit message.
FDO143
Modified
File: trunk/Providers/SHP/Src/Provider/ShpConnection.cpp https://fdoshp.osgeo.org/source/browse/fdoshp/trunk/Providers/SHP/Src/Provider/ShpConnection.cpp?view=diff&rev=70&p1=trunk/Providers/SHP/Src/Provider/ShpConnection.cpp&r1=69&p2=trunk/Providers/SHP/Src/Provider/ShpConnection.cpp&r2=70
This message was automatically generated by Project Tracker.
More information about the Fdo_issues mailing list
