[fdo][FDO145][Modified] Remove assertions before merging PostGIS FDO to trunk
Mateusz Loskot mateusz at loskot.net
Tue Aug 29 14:52:58 EDT 2006
You can view the artifact detail at the following URL:
    https://fdo.osgeo.org/servlets/Scarab/id/FDO145
Type:
Task
Artifact ID:
FDO145 (Remove assertions before merging PostGIS FDO to trunk)
Modified by:
Mateusz Loskot
mloskot (mateusz at loskot.net)
The following modifications were made to this artifact:
-- Description set to new value:
Old value:
Before attempt to merge fdordbms-postgis branch back to the FDORSBMS's trunk, search through the PostGIS FDO provider source code and remove/comment assertions used during development process.
New value:
The reason of this operation is to fulfill FDO coding policies -> discussed in details on the dev at fdo.osgeo.org list.
This message was automatically generated by Project Tracker.
More information about the Fdo_issues mailing list
