[fdo][FDO147][New] SqlServer 2005: Defect 820804 (onstraint parsing failure on ...
Dan Stoica
dan.stoica at autodesk.com
Wed Aug 30 17:57:49 EDT 2006
You can view the artifact detail at the following URL:
https://fdo.osgeo.org/servlets/Scarab/id/FDO147
Type
Defect
Artifact ID
FDO147 (SqlServer 2005: Defect 820804 (onstraint parsing failure on SQL Server 2005))
Reported by
Dan Stoica
danstoica (dan.stoica at autodesk.com)
New artifact details:
- Artifact created
- Summary set to new value
- Description set to new value
The constraints parser does not understand the new syntax in SqlServer 2005:
"([intlist]=(30) OR [intlist]=(20) OR [intlist]=(10))"
Note the extra parentheses. In SqlServer 2000 it used to be:
"([intlist] = 30 or ([intlist] = 20 or [intlist] = 10))"
- Artifact Status set to new value
New
This message was automatically generated by Project Tracker.
More information about the Fdo_issues
