[fdo][FDO148][New] build fails for directory containing spaces
Derrick Oswald
Derrick.Oswald at Autodesk.com
Wed Aug 30 18:04:54 EDT 2006
You can view the artifact detail at the following URL:
https://fdo.osgeo.org/servlets/Scarab/id/FDO148
Type
Defect
Artifact ID
FDO148 (build fails for directory containing spaces)
Reported by
Derrick Oswald
derrickoswald (Derrick.Oswald at Autodesk.com)
New artifact details:
- Artifact Status set to new value
New
- Status Explanation set to new value
Workaround:
Use dir/x to determine the 8.3 path for [FDO OpenSource] and use this.
- Defect Severity set to new value
Low
- Component set to new value
- Artifact created
- Priority set to new value
P5
- Steps to Reproduce set to new value
1) Assign environment variables with a space, e.g.
SET FDO=C:\Data Files\osgeo\fdocore\Fdo
2) Try to build.
- Description set to new value
If the location of [FDO OpenSource] contains spaces the build fails.
- Summary set to new value
This message was automatically generated by Project Tracker.
More information about the Fdo_issues
